Asus Radeon RX 580 Strix Gaming Top OC Review
April 18, 2017 | 13:59
Tags: #polaris #radeon #rx-480 #rx-580
Companies: #amd #asus
Test Setup
Our GPU test rig uses Intel's Z170 platform. Specifically, we use the Asus ROG Maximus VIII Hero Alpha paired with an Intel Core i7-6700K. With four cores and eight threads via HyperThreading, the CPU ensures even the most multi-threaded games won't be bottlenecked, and we've overclocked it to 4.5GHz as well with a base clock of 100MHz, a multiplier of 45 and a vcore of 1.28V, further alleviating CPU bottlenecks. The CPU is paired with 16GB (4 x 4GB) of Corsair Vengeance LPX DDR4 clocked at 3,000MHz and cooled by a Corsair Hydro Series H100i GTX.
The rig is powered by the Corsair AX1500i, which has enough wattage and 8-pin PCI-E power connectors to deal with any multi-GPU set-up we care to throw at it. It's all housed inside a Corsair Graphite Series 760T, which is spacious enough for any card. The final component is an OCZ Vector 180 960GB SSD, giving us plenty of space for game installs.
Our results come from a mix of built-in benchmarks and custom, manually played sections, depending on the game. All benchmarks are repeated at least three times to ensure consistency. We test at 1,920 x 1,080 (1080p) and 2,560 x 1,440 (1440p), as well as at 3,840 x 2,160 (4K) with higher end cards. The operating system is an up-to-date copy of Windows 10 64-bit.
Test System
AMD Graphics Cards
  • Asus Radeon RX 580 Strix Gaming Top OC 8GB - 1,411MHz GPU, 8Gbps GDDR5 (Radeon Software Crimson RX 500 series launch driver)
  • Sapphire Radeon RX 480 Nitro+ OC 8GB - 1,342MHz GPU, 8Gbps GDDR5 (Radeon Software Crimson 17.4.2)
  • Sapphire Radeon RX 480 Nitro+ OC 4GB - 1,306MHz GPU, 7Gbps GDDR5 (Radeon Software Crimson 17.4.2)
  • Sapphire Radeon RX 470 Nitro+ OC 4GB - 1,260MHz GPU, 7Gbps GDDR5 (Radeon Software Crimson 17.4.2)
  • AMD Radeon R9 Fury X 4GB - 1,050MHz GPU, 1Gbps HBM (Radeon Software Crimson 17.2.1)
Nvidia Graphics Cards
  • Aorus GeForce GTX 1080 Ti 11GB - 1,5849MHz GPU (1,708MHz boost), 11Gbps GDDR5X (GeForce 381.65)
  • Inno3D GeForce GTX 1080 Ti iChill X3 11GB - 1,607MHz GPU (1,721MHz boost), 11.4Gbps GDDR5X (GeForce 378.78 launch driver)
  • Nvidia GeForce GTX 1080 Ti Founders Edition 11GB - 1,480MHz GPU (1,582MHz boost), 11Gbps GDDR5X (GeForce 378.78 launch driver)
  • Nvidia Titan X Pascal - 1,418MHz GPU (1,531MHz boost), 12Gbps GDDR5X (GeForce 378.78 launch driver)
  • EVGA GeForce GTX 1080 FTW 8GB - 1,721MHz (1,860MHz boost), 10Gbps GDDR5X (GeForce 378.66)
  • Palit GeForce GTX 1070 GameRock Premium Edition 8GB - 1,670MHz GPU (1,873MHz boost), 8.5Gbps GDDR5 (GeForce 381.65)
  • Nvidia GeForce GTX 1060 Founders Edition 6GB - 1,506MHz GPU (1,708MHz boost), 8Gbps GDDR5 (GeForce 381.65)
  • Gigabyte GeForce GTX 1060 WindForce OC 3GB - 1,582MHz GPU (1,797MHz boost), 8Gbps GDDR5 (GeForce 381.65)
null
