Pixel Shader Performance
Tests
Test Kit
-  Intel Core i7 965 processor (3.2GHz: 133MHz x 24)
-  Asus P6T V2 motherboard (Intel X58 Express)
-  6GB Corsair TR3X6G1333C9 DDR3 memory (3x 2GB, 1,333MHz, CL9)
-  Corsair X128 SSD
-  Corsair HX1000W PSU
-  Windows Vista Home Premium x86-64 (with Service Pack 2)
-  Antec Twelve Hundred Chassis
-  HD 5870: Catalyst 8.66 RC6 Windows Vista/7 (September 11th Build)
-  All other ATI: Catalyst 9.9 WHQL
- ] Nvidia: ForceWare 190.38 WHQL
        ATI Radeon HD 5870 1GB
        Nvidia GeForce GTX 285 1GB
        ATI Radeon HD 4890 1GB
        Nvidia GeForce 8800 GTX 768MB
        ATI Radeon HD 3870 512MB
Frames Per Second
Frames Per Second
          50
          75
          100
          125
          150
          175
    Frames Per Second
          200
          300
          400
          500
          600
          700
    Frames Per Second
          200
          300
          400
          500
          600
          700
          800
          900
    Frames Per Second
Frames Per Second
          500
          750
          1000
          1250
          1500
          1750
    Frames Per Second
With an exception of the RightMark 3D 2.0 Steep Parallax Mapping test, which is both pixel shader- and texture-bound, the Radeon HD 5870 shows off its phenomenal raw pixel shader throughput in these tests. The 3DMark Vantage Perlin Noise test is a bit of an extreme example, delivering more than two and a half times the performance of the Radeon HD 4890, but it shows that AMD has really delivered a potentially very fast GPU.
