Battlefield 4 Performance Analysis
November 27, 2013 | 10:02
Tags: #1080p #4k #amd-eyefinity #battlefield-4 #bf4 #nvidia-surround
Companies: #amd #dice #nvidia
Battlefield 4 - Memory Performance
Recent blog posts over at Corsair suggested that the speed of your memory could also play a part, and we were keen to briefly put this to the test as well. We did this simply by decreasing our memory frequency through the usual stages from 2,400MHz to 1,333MHz and running the 1,920 x 1,080 test at all four presets with the fastest single GPU card overall, the R9 290X.
BF4 RAM Performance - R9 290X 4GB (Uber Mode)
1,920 x 1,080, DirectX 11, ultra detail preset
  • 8GB 2,400MHz
  • 8GB 2,133MHz
  • 8GB 1,866MHz
  • 8GB 1,600MHz
  • 8GB 1,333MHz
    • 59
    • 71
    • 59
    • 71
    • 59
    • 71
    • 59
    • 71
    • 58
    • 70
20
30
40
50
60
70
Frames Per Second
  • Minimum
  • Average
1,920 x 1,080, DirectX 11, high detail preset
  • 8GB 2,400MHz
  • 8GB 2,133MHz
  • 8GB 1,866MHz
  • 8GB 1,600MHz
  • 8GB 1,333MHz
    • 86
    • 105
    • 85
    • 105
    • 84
    • 103
    • 84
    • 103
    • 83
    • 102
50
75
100
Frames Per Second
  • Minimum
  • Average
1,920 x 1,080, DirectX 11, medium detail preset
  • 8GB 2,400MHz
  • 8GB 2,133MHz
  • 8GB 1,866MHz
  • 8GB 1,333MHz
  • 8GB 1,600MHz
    • 120
    • 141
    • 120
    • 141
    • 118
    • 139
    • 115
    • 137
    • 114
    • 138
50
75
100
125
150
Frames Per Second
  • Minimum
  • Average
1,920 x 1,080, DirectX 11, low detail preset
  • 8GB 2,400MHz
  • 8GB 2,133MHz
  • 8GB 1,600MHz
  • 8GB 1,866MHz
  • 8GB 1,333MHz
    • 137
    • 159
    • 137
    • 159
    • 136
    • 157
    • 135
    • 156
    • 134
    • 153
50
75
100
125
150
175
Frames Per Second
  • Minimum
  • Average
As with the CPU results, this is a fairly easy set of results to assess. There's a little more variation than we saw with the CPU tests, and a general pattern of a few lost frames as you get lower down the set of memory frequencies. However, it's only ever a maximum of 5 percent between the best and worst results (although they were still repeatable patterns). Therefore, while it appears that the engine does place some degree of stress on the memory subsystem, it's still hugely GPU limited, even at low settings.
As we said before, however, the CPU (and consequently the memory) could have a larger role to play when it comes to multiplayer, the mode where most people are likely to spend their BF4 playtime. Corsair's own testing was done on multiplayer servers, for example, and their system was also a Haswell one, whereas ours is an Ivy Bridge based rig, which could also make a difference. Much of this is speculation, of course, and there is (as ever) more room for testing how your memory specifications might affect performance in game.
