Power Consumption:
On top of our graphics performance testing, we have also measured the power consumption of the BFG Tech GeForce 9600 GT OC 512MB graphics card at both idle and load. For this we used the same test system as we've used across all of our performance testing.
The system was configured as follows:
- Core 2 Duo E6750 (operating at 2.66GHz -- 8x333MHz)
- Gigabyte X38-DS5 motherboard (Intel X38 Express)
- 2 x 1GB OCZ FlexXLC PC-9200 memory (operating in dual-channel at DDR2-800 with 4-4-4-12 timings)
- Seagate Barracuda 7200.9 160GB SATA hard drive
- PC Power & Cooling 750W Silencer
- Windows Vista Ultimate x86
For our idle testing, we left the systems idling on the desktop for ten minutes, recording the average draw at the wall socket. For load testing, we used our benchmark routine from
Crysis in DirectX 10 mode (DirectX 9 mode was used for the Radeon X1950 Pro) and measured the peak power consumption in this section of the title. We tested the cards in a number of other scenarios and this proved to be the most intensive in all cases, so you can consider this to be a worst-case scenario.
Bear in mind that we have disabled all CPU-related power management options in the motherboard's BIOS so that we can highlight exactly how well the GPU's power management features are working.
ATI Radeon HD 3850 256MB
ATI Radeon HD 3870 512MB
PowerColor Radeon HD 3850 Xtreme PCS 512MB
Nvidia GeForce 8600 GTS 256MB
HIS Radeon HD 3850 IceQ 3 TurboX 512MB
ATI Radeon X1950 Pro 256MB
Nvidia GeForce 9600 GT 512MB
Nvidia GeForce 8800 GS 384MB
BFGTech GeForce 9600 GT OC 512MB
Zotac GeForce 9600 GT 512MB AMP! Edition
Nvidia GeForce 8800 GT 512MB
90
94
95
95
95
99
101
101
102
105
110
Power at socket (W)
147
156
157
161
167
167
170
172
178
182
185
Power at socket (W)
While idle power consumption compared to the Radeon HD 3800-series cards isn't fantastic, it does pick up a bit of ground under load. That said, loaded power consumption isn't really the biggest issue, because your graphics card spends the majority of its time sitting idle on the Windows desktop.
