Deus Ex: Mankind Divided Benchmarked - 1080p
1080p, also known as FullHD, is still by far the most popular desktop resolution and the one that most gamers are interested in - it is used by nearly 40 percent of gamers according to the latest Steam Hardware Survey results.
        Nvidia GeForce Titan X (Pascal) 12GB
        Inno3D GeForce GTX 1080 iChill X3 8GB
        MSI GeForce GTX 1070 Gaming X 8GB
        AMD Radeon R9 Fury X 4GB
        Nvidia GeForce GTX 980 Ti 6GB
        Sapphire Radeon R9 Fury Nitro 4GB
        Sapphire Radeon R9 390X Nitro 8GB
        Sapphire Radeon RX 480 Nitro 8GB
        Sapphire Radeon R9 390 Nitro 8GB
        Sapphire Radeon RX 480 Nitro 4GB
        Nvidia GeForce GTX 980 4GB
        Nvidia GeForce GTX 1060 Founders Edition 6GB
        XFX Radeon RX 470 RS 4GB
        Asus GeForce GTX 970 DirectCU Mini 4GB
        Sapphire Radeon R9 380X Nitro 8GB
        Sapphire Radeon R9 380 ITX Compact 4GB
        Asus Radeon R9 280X DirectCU II 3GB
        Palit GeForce GTX 960 Super JetStream 2GB
        Gigabyte GeForce GTX 950 OC 2GB
        Gigabyte Radeon RX 460 WindForce 2X OC 2GB
        MSI GeForce GTX 670 OC 2GB
        Gigabyte GeForce GTX 660 OC 2GB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
Clearly, with all the settings cranked up, Deus Ex is a tough game to run. Only a single card here is able to successfully run the game without dipping below 60fps, and it's the £1,100 GTX Titan X. Thankfully, there are a good number of cards that keep their minimum in the all-important 30-60fps range. AMD seems to do better than Nvidia as well - note that the RX 480 4GB is able to outperform not only the GTX 1060, but also the GTX 980.
    Frames Per Second
Notching things down to 'Very High', most cards improve on average by between 15 and 20 percent, with Nvidia's hardware benefiting the most. At these settings, an overclocked GTX 1080 is now able to provide constant >60fps gameplay, while the GTX 1060, GTX 970 and RX 470 all cross from unplayable into playable i.e. their minimum is now above 30fps. Meanwhile, the RX 480 cards (both the 4GB and 8GB) still look especially strong - they're on par with the previous generation R9 390X and hot on the heels of the R9 Fury and R9 Fury X.
    Frames Per Second
Average frame rates increase by a further 20 percent as you step down to 'High' settings, which are the ones recommended by the developers for the best balance between visual quality and performance. A fair number of high-end cards now average over 60fps, but it's still only the two very best Nvidia cards that never dip below this. The R9 380 and R9 380X join the ranks of >30fps cards as well, but older generation cards like the GTX 660, GTX 670 and R9 280X all struggle. In fact, all cards here with 4GB or more of memory are playable, but those with less than this are not - Deus Ex certainly seems to make heavy use of frame buffers.
    Frames Per Second
Lastly, at 'Medium', which is the lowest settings we'd recommend playing on for a good time, performance is most likely to increase by just under 15 percent or so. Even so, all the 2GB cards still have minimums below 30fps, but the R9 280X 3GB just manages to hit this target. The GTX 1070 also finally exceed 60fps on the minimum, but you're unlikely to buy a GTX 1070 to play at medium settings.
