Thermal Performance
To thermally test the cards we recorded GPU temperatures for each individual core using RivaTuner. Idle readings were taken at the desktop in Windows Vista 64-bit Home Premium with Windows Aero enabled, while the load reading taken while the GPU configuration was running our
Crysis benchmark at 1,920 x 1,200 with 0xAA.
This is one of the most demanding tests in our benchmarking suite, and is sure to get those GPUs sweating. We didn't go higher because we felt that if we increased the load too much, some of the slower cards wouldn't deliver realistic numbers because they'd be bottlenecked in other ways.
All temperatures were taken with the cards cooled using only their standard stock coolers and running on our open air test benches, which have no additional airflow other than that present in the room.
Gigabyte ATI HD Radeon 4770 512MB
ATI Radeon HD 4770 512MB
Nvidia GeForce GTS 250 512MB
Nvidia GeForce 9800 GT 512MB
ATI Radeon HD 4850 512MB
ATI Radeon HD 4830 512MB
XFX GeForce 9600 GSO XXX Edition 384MB
20
30
40
50
60
70
80
Temperature (°C)
After little distinction between the two cards in games testing we finally start to see some differentiation between the Gigabyte and reference design. The custom cooler managed to keep the GPU a whole (!) two degrees cooler at idle. This is most likely down to the fact that the fan is single speed so while the reference model is fractionally hotter when the GPU is idle, its PWM makes the fan spin slowly and quietly.
XFX GeForce 9600 GSO XXX Edition 386MB
Temperature (°C)
Fire up the
Crysis benchmark and the cracks start to appear in Gigabyte's custom cooler. The reference design kept the GPU three degrees cooler with the GPU under load and was also quieter even with the fan spun up.
