Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 3.0 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 2,560 x 1,600. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
        AMD Radeon HD 7750 1GB
        AMD Radeon HD 7770 1GB
        AMD Radeon HD 7870 2GB
        Nvidia GeForce GTX 650 1GB
        AMD Radeon HD 7970 3GB
        Gigabyte GeForce GTX 670 2GB
        AMD Radeon HD 7950 3GB
        Nvidia GeForce GTX 660 Ti 2GB
        AMD Radeon HD 7950 3GB with Boost
        AMD Radeon HD 7970 3GB GHz Edition
        Nvidia GeForce GTX 670 2GB
        Nvidia GeForce GTX 660 2GB
        Nvidia GeForce GTX 680 2GB
        AMD Radeon HD 7850 2GB
        EVGA GeForce GTX 650 Ti 1GB SSC
        Nvidia GeForce GTX 690 4GB
            71
            72
            75
            76
            80
            80
            80
            80
            80
            80
            80
            80
            81
            86
            87
            90
          20
          30
          40
          50
          60
          70
          80
          90
    System Power consumption in Watts
            112
            126
            145
            166
            173
            192
            205
            224
            227
            240
            241
            262
            265
            273
            314
            389
Thermal Performance (Idle and Gaming)
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
            6
            8
            9
            10
            10
            11
            11
            11
            11
            11
            12
            14
            14
            15
            16
          8
          10.5
          13
          15.5
          18
    Delta T in °C
        AMD Radeon HD 7970 3GB GHZ Editon
            29
            37
            38
            40
            41
            42
            43
            44
            50
            53
            54
            54
            55
            57
            63
    Delta T in °C
*as there's no stock model of the HD 7850 2GB, it is not included in these graphs
