Deus Ex: Mankind Divided
Publisher: Square Enix Holdings
Click to enlarge Deus Ex: Mankind Divided is our second DirectX 12 title. We test using
the 'Ultra' preset, and at these settings it is currently one of the
toughest games to run smoothly, presenting a challenge for even flagship
graphics cards. We run the built-in benchmark (hidden in the 'Extras'
menu), as it is very consistent and makes full use of the engine's
features. We also rely on the game's own frame rate counter since FRAPS
does not currently work with this game when using DirectX 12. We've
actually found that your experience in-game will typically be with frame
rates a little higher than the average frame rate from the
benchmark, but even so it's the minimum frame rate that we focus on and
that you should really take into consideration, because it's in the most
challenging parts of the game that you'll really feel the slowdowns, and
it's no good having a sub-par experience in the heat of battle.
