Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we loop the Unigine Valley 1.0 benchmark (2,560 x 1,400, 'Ultra' detail, no anti-aliasing), which is a very GPU-limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (3,840 x 2,160).
Gigabyte Radeon RX 460 WindForce 2X OC 2GB
MSI GeForce GTX 1050 Ti Gaming X 4GB (Gaming Mode)
MSI GeForce GTX 1050 Ti Gaming X 4GB (OC Mode)
MSI GeForce GTX 1050 Ti Gaming X 4GB (Silent Mode)
Gigabyte GeForce GTX 950 OC 2GB
Gigabyte GeForce GTX 1060 WindForce OC 3GB
Sapphire Radeon RX 470 Nitro OC 4GB
System Power Draw in Watts (Lower Is Better)
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark. The GPU is installed in a closed, but fairly well ventilated case (Corsair Graphite 760T) with HDD cages removed and the case fans at full speed. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (3,840 x 2,160).
Delta T in °C (Lower Is Better)
