Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we run our Unigine Valley 1.0 benchmark, which is our most GPU limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (3,840 x 2,160).
Palit GeForce GTX 960 Super JetStream 2GB
Nvidia GeForce GTX 1060 Founders Edition 6GB
Asus GeForce GTX 970 DirectCU Mini 4GB
MSI GeForce GTX 1070 Sea Hawk X 8GB (Silent Mode)
MSI GeForce GTX 1070 Sea Hawk X 8GB (Gaming Mode)
AMD Radeon RX 480 8GB
MSI GeForce GTX 1070 Sea Hawk X 8GB (OC Mode)
AMD Radeon RX 480 4GB
Nvidia GeForce GTX 980 4GB
Sapphire Radeon R9 380 ITX Compact 4GB
Asus GeForce GTX 1070 Strix 8GB
EVGA GeForce GTX 1080 FTW 8GB
Nvidia GeForce GTX 980 Ti 6GB
AMD Radeon R9 Fury X 4GB
Sapphire Radeon R9 390X Nitro 8GB
System Power Draw in Watts (Lower Is Better)
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark. The GPU is installed in a closed, but fairly well ventilated case (Corsair Graphite 760T) with HDD cages removed and the case fans at full speed. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (3,840 x 2,160).
Delta T in °C (Lower Is Better)
