Crysis 3
Publisher: EA
Mixing the open-world combat of Crysis with the more tightly scripted urban jungle of Crysis 2, Crysis 3 is a smorgasbord of visual effects and polygons galore. With DirectX 11 support, high resolution textures and incredibly detailed characters models, it's laid down the gauntlet  for the next generation of consoles and  games alike when it comes to gorgeous graphics
We test using the Very High detail preset and with Very High texture resolution. lens flare and motion blur are both enabled, although due to its heavy performance impact, anti-aliasing is disabled.
As explained earlier, we use a custom macro-driven 60 seconds play-through from the single player mission Red Star Rising. The 60 seconds of gameplay takes place in a large open environment heavy on water and particle effects. Each test is repeated three times, with the average result taken.
        AMD Radeon R9 295X2 8GB
        Nvidia GeForce GTX Titan X 12GB
        Nvidia GeForce GX 980 Ti 6GB
        Nvidia GeForce GTX 980 4GB
        Nvidia GeForce GTX Titan Black 6GB
        Nvidia GeForce GTX 780 Ti 3GB
        MSI GTX 970 Gaming 4G 4GB (factory overclocked)
        AMD Radeon R9 290X 4GB
        Nvidia GeForce GTX 780 3GB
        AMD Radeon R9 290 4GB
        Nvidia GeForce GTX 770 2GB
        AMD Radeon R9 280X 3GB
        AMD Radeon R9 285 2GB
        MSI GTX 960 Gaming 2G 2GB (factory overclocked)
        Nvidia GeForce GTX 760 2GB
        AMD Radeon R9 280 3GB
        AMD Radeon R9 270X 2GB
        Nvidia GeForce GTX 660 2GB
        AMD Radeon R9 270 2GB
        AMD Radeon R7 265 2GB
        Nvidia GeForce GTX 750 Ti 2GB
        AMD Radeon R7 260X 2GB
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
    Frames Per Second
