Crysis 3
Publisher: EA
Mixing the open-world combat of Crysis with the more tightly scripted urban jungle of Crysis 2, Crysis 3 is a smorgasbord of visual effects and polygons galore. With DirectX 11 support, high resolution textures and incredibly detailed characters models, it's laid down the gauntlet  for the next generation of consoles and  games alike when it comes to gorgeous graphics
We test using the Very High detail preset and with Very High texture resolution. lens flare and motion blur are both enabled, although due to its heavy performance impact, anti-aliasing is disabled.
As explained earlier, we use a custom macro-driven 60 seconds play-through from the single player mission Red Star Rising. The 60 seconds of gameplay takes place in a large open environment heavy on water and particle effects. Each test is repeated three times, with the average result taken.
        Nvidia GeForce GTX 690 4GB
        AMD Radeon HD 7990 6GB
        Nvidia GeForce GTX 780 Ti 3GB
        Nvidia GeForce GTX Titan 6GB
        AMD Radeon R9 290X 4GB
        Nvidia GeForce GTX 780 3GB
        AMD Radeon R9 290 4GB
        Nvidia GeForce GTX 770 2GB
        Nvidia GeForce GTX 680 2GB
        Nvidia GeForce GTX 670 2GB
        AMD Radeon R9 280X 3GB
        AMD Radeon HD 7970 3GB GHz Edition
        Nvidia GeForce GTX 760 2GB
        Nvidia GeForce GTX 660 Ti 2GB
        AMD Radeon HD 7950 3GB with Boost
        AMD Radeon R9 270X 2GB
        Nvidia GeForce GTX 660 2GB
        AMD Radeon HD 7870 2GB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
    Frames Per Second
    Frames Per Second
    Frames Per Second
