A closer inspection...
Back when we reviewed GeForce 7900 GX2, we took the time to take the card apart in order to explain how the technology works from a physical perspective. In essence, the GeForce 7950 GX2 uses many of the same principles as the GeForce 7900 GX2, but the implementation is a little more refined in order to get Quad SLI ready for the mass market.
NVIDIA GeForce 7950 GX2 How it works... NVIDIA GeForce 7950 GX2 How it works...
The card still uses a PCI-Express switch between the two PCBs, but there is only a single SLI connector, shared between the two PCBs. Afterall, both GPUs on the GeForce 7950 GX2 communicate via the on-board PCI-Express switch. When using two GeForce 7950 GX2s in Quad SLI, there is only a need to combine data from the two cards and not between all four GPUs because this is basically SLI on a single video card - the two GPUs act together as one. This is a change from the GeForce 7900 GX2 which - when running in Quad SLI - required two SLI bridge connectors, thus creating one rather complex loop.
As a result of using a 48-lane PCI-Express switch between the two PCBs, there is a need for a bridge chip in order to make the GPUs work together in tandem. Typically, a pair of GPUs working in SLI mode send data across the SLI bridge connector and PCI-Express bus. Obviously, there is no physical PCI-Express bus between the two GPUs on the GeForce 7950 GX2, so NVIDIA had to make its own using a PCI-Express to PCI-Express bridge chip. This is very similar to the AGP to PCI-Express (and PCI-Express to AGP) bridge chip that we have seen on a number of NVIDIA products where the SKU wasn't using the GPUs' native bus interconnect.
The PCI-Express switch between the two PCBs uses a slightly different connection on GeForce 7950 GX2. GeForce 7900 GX2 used a pair of connectors to send data between the two GPUs, now there is only a single connection in between the boards. This is the same size as the larger of the two connectors on NVIDIA's previous dual-GPU video card implementation.
