PowerColor Radeon HD 3850 Xtreme PCS 512
Written by Tim Smalley
February 18, 2008 | 04:49
Tags: #3850 #512mb #8800 #bundle #color #extreme #geforce #gs #hd #performance #power #professional #radeon #review #rv670 #system
Companies: #amd #ati #powercolor
Power Consumption:
On top of our graphics performance testing, we have also measured the power consumption of PowerColor's Radeon HD 3850 Xtreme PCS 512MB graphics card at both idle and load. For this we used the same test system as we've used across all of our performance testing.
The system was configured as follows:
  • Core 2 Duo E6750 (operating at 2.66GHz -- 8x333MHz)
  • Gigabyte X38-DS5 motherboard (Intel X38 Express)
  • 2 x 1GB OCZ FlexXLC PC-9200 memory (operating in dual-channel at DDR2-800 with 4-4-4-12 timings)
  • Seagate Barracuda 7200.9 160GB SATA hard drive
  • PC Power & Cooling 750W Silencer
  • Windows Vista Ultimate x86
For our idle testing, we left the systems idling on the desktop for ten minutes, recording the average draw at the wall socket. For load testing, we used our benchmark routine from Crysis in DirectX 10 mode (DirectX 9 mode was used for the Radeon X1950 Pro) and measured the peak power consumption in this section of the title. We tested the cards in a number of other scenarios and this proved to be the most intensive in all cases, so you can consider this to be a worst-case scenario.
Bear in mind that we have disabled all CPU-related power management options in the motherboard's BIOS so that we can highlight exactly how well the GPU's power management features are working.
Idle Power Consumption
Windows Vista Desktop (Aero Enabled)
  • ATI Radeon HD 3850 256MB
  • ATI Radeon HD 3870 512MB
  • PowerColor Radeon HD 3850 Xtreme PCS 512MB
  • Nvidia GeForce 8600 GTS 256MB
  • ATI Radeon X1950 Pro 256MB
  • Nvidia GeForce 8800 GS 384MB
  • Nvidia GeForce 8800 GT 512MB
  • 90
  • 94
  • 95
  • 95
  • 99
  • 101
  • 110
50
75
100
125
Power at socket (W)
Loaded Power Consumption
Crysis DX9 at 1280x1024 0xAA 0xAF
  • 147
  • 156
  • 157
  • 161
  • 167
  • 182
  • 185
100
150
200
Power at socket (W)
What's interesting here is that while the idle power consumption is 1W higher than a Radeon HD 3870 reference card, the loaded power consumption is 24W lower – that's not a bad result considering the card is typically just a few frames per second slower than its bigger brother. It also consumes 8W less power than the GeForce 8800 GS at load too, which is another good result for PowerColor's factory overclocked Radeon HD 3850.
