Quake 4
Publisher:
Activision
We used the full retail version of
Quake 4 patched to version 1.3.0. It's the fourth game in the
Quake series, based on the technically sound
Doom 3 engine. However, unlike
Doom 3, we found that the game benefits from at least 2x anti-aliasing, and the experience with anti-aliasing at a slightly lower resolution was better than increasing the resolution with no AA applied.
Both anti-aliasing and anisotropic filtering were controlled from inside the game. When you select "High Quality" mode, 4xAF is automatically enabled, and when the "Ultra Quality" mode is enabled, 8xAF is automatically applied to the scene.
We used a custom-recorded demo from a section that represents fairly typical performance throughout the rest of the game. We set the in-game details to high quality and left Vsync disabled. Both anti-aliasing and anisotropic filtering were controlled inside the game using console commands. Anti-aliasing was adjusted using the "r_multisamples" cvar, while anisotropic filtering values were set using "image_anisotropy".
Nvidia GeForce 8800 GTX 768MB SLI
ATI Radeon X1950 XTX 512MB CrossFire
BFGTech GeForce 8800 GTS OC 640MB SLI
BFGTech GeForce 8800 GTS OC 320MB SLI
ATI Radeon HD 2900 XT 512MB CrossFire
Nvidia GeForce 8800 Ultra 768MB
Nvidia GeForce 7900 GTX 512MB
50
75
100
125
150
175
Frames Per Second
50
75
100
125
150
175
Frames Per Second
Frames Per Second
Frames Per Second
Being based on the same engine as
Prey, we expected to see similar performance characteristics on the Radeon HD 2900 XT. This was largely the case and at 2560x1600, the Radeon HD 2900 XT not only outperformed the GeForce 8800 GTS by a comprehensive margin, it also managed to the GeForce 8800 GTX its ass in style.
Not only did it beat it in single card mode, but it also managed to beat it in dual card mode too. It's a double whammy, boyo. This is probably thanks to the improvements AMD has made to stencil shadowing in R600.
