Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster!  It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game.  We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
        Nvidia GeForce GTX 280 1GB SLI
        Nvidia GeForce GTX 295 1,792MB
        Nvidia GeForce GTX 260-216 896MB SLI
        ATI Radeon HD 4870 1GB CrossFire
        ATI Radeon HD 4870 X2 2GB
        Sapphire ATI Radeon HD 4850 X2 2GB
        Nvidia GeForce GTX 285 1GB
        Sapphire ATI Radeon HD 4870 1GB Toxic
        ATI Radeon HD 4870 512MB
Frames Per Second
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
        Sapphire ATI Radeon HD 4850 X2 2GB0.0
Frames Per Second
Frames Per Second
Frames Per Second
Nothing much has changed here - there's the familiar pattern of Nvidia's GeForce GTX 260-216 outperforming the Radeon HD 4870 offerings and the additional frame buffer making very little difference.  The sweetspot for this card doesn't change from what we experienced in DirectX 10 mode with all in-game details set to high, although there may be enough headroom for 2xAA to be enabled since the Toxic gets very close to delivering an average of 30 frames per second at 1,680 x 1,050 4xAA 16xAF.
