Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we run our Unigine Valley 1.0 benchmark, which is our most GPU limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (3,840 x 2,160).
        Sapphire Radeon R7 370 Nitro OC 4GB
        Gigabyte GeForce GTX 950 OC 2GB
        Palit GeForce GTX 960 Super JetStream 2GB
        Nvidia GeForce GTX 1060 Founders Edition 6GB
        Asus GeForce GTX 970 DirectCU Mini 4GB
        AMD Radeon RX 480 8GB
        AMD Radeon RX 480 4GB
        Nvidia GeForce GTX 980 4GB
        Sapphire Radeon R9 380 ITX Compact 4GB
        Sapphire Radeon RX 470 Nitro OC 4GB
        Asus GeForce GTX 1070 Strix OC 8GB
        EVGA GeForce GTX 1080 FTW 8GB
        Nvidia GeForce GTX 980 Ti 6GB
        AMD Radeon R9 Fury X 4GB
        Sapphire Radeon R9 390X Nitro 8GB
    System Power Draw in Watts (Lower Is Better)
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark. The GPU is installed in a closed, but fairly well ventilated case (Corsair Graphite 760T) with HDD cages removed and the case fans at full speed. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (3,840 x 2,160).
    Delta T in °C (Lower Is Better)
