Publisher: Activision
Call of Duty: World at War is Treyarch’s controversial World War II shooter set on the Pacific and Eastern fronts, where you switch roles between an American Marine and a Russian soldier who survives Stalingrad and follows the push into Berlin at the end of the war.
World at War uses a beefed up version of the proprietary engine used in
Call of Duty 4: Modern Warfare, which was developed by Infinity Ward and has easily been the most successful game in the series. It uses the DirectX 9.0 renderer exclusively and features true world dynamic lighting, HDR lighting, dynamic shadowing and depth of field amongst other things.
We used the full retail version of the game downloaded from Steam, which was patched to version 1.1 and for our gameplay testing, we did a 90-second manual run through from the second mission in the game where you are part of a beach landing in the Pacific. It appears to be one of the more intensive parts of the game with lots of explosions, water, smoke and lighting effects thrown in for good measure.
All of the in-game settings were set to their maximum values, including texture details which were configured to 'Extra'. The 'Dual Video Cards' option was enabled for the multi-GPU configurations, but was disabled for all single GPU cards. Finally, anti-aliasing and anisotropic filtering were controlled from inside the game.
ATI Radeon HD 4850 512MB
ATI Radeon HD 4830 512MB
XFX GeForce 9800 GT 512MB XXX Edition
Nvidia GeForce 9800 GT 512MB
Nvidia GeForce 9600 GT 512MB
Nvidia GeForce 9600 GSO 384MB
ATI Radeon HD 4670 512MB
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Just as in
Fallout 3, the XFX GeForce 9800 GT 512MB XXX Edition is clearly well ahead of the stock 9800 GT, especially when 4xAA is applied. Minimum frame rates are also improved, but it's the performance advantage at 1,680 x 1,050 4xAA that's the most interesting, with an improvement of over ten percent versus a stock 9800GT. Sadly though, even when heavily overclocked the 9800 GT struggles to best the Radeon HD 4830 and is still some way off the performance of the comparably priced Radeon HD 4850.
