Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent
Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more Fallout games in the future.
Despite using the
Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since
Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60fps cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
         Nvidia GeForce GTS 250 512MB
        ATI Radeon HD 4850 512MB
        Nvidia GeForce 9800 GT	 512MB
        Gigabyte ATI Radeon HD 4770 512MB
        XFX ATI Radeon HD 4770 512MB
         ATI Radeon HD 4830 512MB
        XFX GeForce 9600 GSO XXX Edition 384MB
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
All the HD 4770s managed playable frame rates at 1,280 x 1,024 2xAA 16xAF with the XFX ATI Radeon HD 4770 512MB managing a minimum of 25fps. The ATI Radeon HD 4830 512MB recorded very similar frame rates while the ATI Radeon HD 4850 512MB and Nvidia GeForce GTS 250 512MB especially were much faster. It was significantly quicker than the XFX GeForce 9600 GSO XXX Edition 384MB though which is definitely showing its age.
