Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and
www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
        Intel Core i7-4960X (3.6GHz/4.4GHz)
        Intel Core i7-4770K (3.5GHz/4.7GHz)
        Intel Core i7-5930K (3.5GHz/4.55GHz)
        Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
        Intel Core i7-4790K (4GHz/4.8GHz)
        Intel Core i7-5960X (3GHz/4.45GHz)
        Intel Core i7-5820K (3.3GHz/4.3GHz)
        Intel Core i7-4930K (3.4GHz/4.5GHz)
        Intel Core i7-3930K (3.2GHz/4.7GHz)
        Intel Core i3-4130 (3.4GHz)
        AMD FX-8350 (4GHz/4.8GHz)
        Intel Pentium G3258 (3.2GHz/4.8GHz)
        Intel Core i7-4800MQ (2.7GHz)
        Intel Core i7-5700HQ (2.7GHz)
        Intel Core i7-4720HQ  (2.6GHz)
        Intel Core i5-5200U (2.2GHz)
    Score, higher is better
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
        Intel Core i5-4670K (3.4GHz/4.6GHz)
          1000
          1500
          2000
          2500
          3000
          3500
