Intel Haswell-E; Intel Core i7-5960X Review, X99 Chipset and DDR4
Written by Antony Leather
August 29, 2014 | 16:58
Tags: #haswell-e #haswell-e-review #intel-core-i7-5820k-review #intel-core-i7-5930k-review #intel-core-i7-5960x-review #lga2011-v3 #x99 #x99-review
Companies: #intel
PCMark 8 Video and Photo Editing
Video Editing v2 Part 2 (Creative 3.0 test suite)
This workload uses FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The Part 2 test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
PCMark 8 4K Video Editing
Part 2 test
  • Intel Core i7-4790K (4GHz/4.8GHz)
  • Intel Core i7-4930K (3.4GHz/4.5GHz)
  • Intel Core i7-5960X (3GHz/4.45GHz)
  • Intel Core i7-3960X (3.3GHz/4.7GHz)
  • AMD FX-8350 (4GHz/4.6GHz)
    • 112
    • 107
    • 136
    • 119
    • 138
    • 108
    • 138
    • 125
    • 542
    • 472
200
300
400
500
600
Seconds, lower is better
  • Stock
  • Overclocked
PCMark 8 Photo editing V2 (Creative 3.0 test suite)
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
    • 31
    • 26
    • 32
    • 26
    • 32
    • 27
    • 38
    • 36
    • 64
    • 53
20
30
40
50
60
70
  • Stock
  • Overclocked
Batch Photo Editing v2 (Creative 3.0 test suite)
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size.
PCMark 8 Batch Photo editing
Load image matrix + transforming time
    • 63
    • 51
    • 67
    • 64
    • 70
    • 58
    • 71
    • 59
    • 145
    • 127
50
75
100
125
150
  • Stock
  • Overclocked
null
