Intel DZ87KL-75K Review - A Last Hurrah
Written by Antony Leather
June 21, 2013 | 05:47
Tags: #best-lga1150-motherboard #intel-haswell #intel-z87 #lga1150-motherboard #lga1155 #z87
Companies: #haswell #intel
Test Setup
With the exception of ATTO, which we use to measure the performance of a motherboard's SATA controllers, all of our benchmarks use real applications that give you a great idea of how well a product fares when performing the tasks for which you're likely to use it.
We test with our own Media Benchmarks suite, which can be downloaded so that you can test your own system. It uses a combination of Gimp image editing, H.264 encoding with Handbrake and multi-tasking with 7-Zip file compression combined with HD video playback. Finally, for our game testing we benchmark the board running The Elder Scrolls: Skyrim and Total War: Shogun 2's DX9 CPU test and record the minimum and average frame rates.
*Intel DZ87KL-75K Review - A Last Hurrah Intel DZ87KL-75K Review Test Setup
Our benchmarks include stable overclocked results too, so you can gauge how much performance potential there is in the motherboard, and how much value this adds to your purchase. We ran the memory at 1,600MHz so our results would be comparable to previous results in many of our benchmarks for CPUs that we're no longer able to test.
Motherboards:
  • Intel DZ87KLT-75K
  • Asus Maximus VI Extreme
Common Components:
  • Intel Core i7-4770K
  • 16GB Corsair Vengreance Pro DDR3 1,866MHz
  • Nvidia GeForce GTX 680 2GB
  • Corsair Pro Series Gold HX750 power supply
  • 128GB OCZ Vector SSD
  • Windows 7 Home Premium 64-bit
Overclocked Settings:
  • Intel DZ87KLT-75K - 4.7GHz, 100MHz Base Clock, 47x multiplier, 1,600MHz RAM
  • Asus Maximus VI Extreme - 4.7GHz, 100MHz Base Clock, 47x multiplier, 1,600MHz RAM
Posted by B1GBUD - Fri Jun 21 2013 08:12
What?? No score?
Edit: nevermind, shame there isn't any stock.
Posted by GuilleAcoustic - Fri Jun 21 2013 08:55
Too bad they aren't doing motherboard anymore. I'm pretty affraid for the future of the thin-ITX form factor.
Posted by Gtek - Fri Jun 21 2013 09:16
GuilleAcoustic
Exactly my fear...
Posted by Stanley Tweedle - Fri Jun 21 2013 09:19
Giant blue sloped roof heatsinks and it has a beeper speaker. I might buy. Then again I might not. No I won't buy although I think my mobo doesn't have a beeper speaker.
null
