AS SSD Benchmark Results
Website:
AS SSD
AS SSD is a freeware benchmarking tool designed just  for SSDs, performing a battery of sequential read and write tests, as well as random read and write tests and sequential access tests over a 3GB portion of the drive. As Windows 7's caching technology makes using  real world based tests such as FC-Test almost impossible, this is the next best thing for judging sequential read and write speeds. It also produces accurate access times, and is wonderfully easy to use.
AS SSD's benchmark uses data that is predominantly incompressible, which negates much of SandForce's DuraWrite compression technology. This means that it can be seen as a worst case scenario for drives that use compression, such as the OCZ Vertex 3.
Sequential Speeds
        OCZ Vertex 3 240GB (Beta SandForce 2281)
        Crucial M4 256GB (Marvell)
        Intel 510 120GB (Marvell)
        Crucial C300 256GB (Marvell)
        Intel X-25M 160GB
        OCZ Vertex 120GB (Indilinx Barefoot)
        G.SKill Phoenix 100GB (SandForce 1222)
MB/sec, Higher Is Better
        OCZ Vertex 3 240GB (SandForce 2281)
        Intel X-25M 160GB
Random Performance
        Crucial M4 256GB
        Intel X-25M 160GB
        Intel X-25M 160GB
          20
          30
          40
          50
          60
          70
          80
        Intel X-25M 160GB
        Intel X-25M 160GB
