Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multithreaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio.  We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
        Core 2 Duo E6750 (2x2.67GHz, 4MB L2, 1333MHz FSB)
        Core 2 Duo E6700 (2x2.67GHz, 4MB L2, 1066MHz FSB)
        Core 2 Duo E6600 (2x2.40GHz, 4MB L2, 1066MHz FSB)
        Athlon 64 X2 6000+ (2x3.0GHz, 2x1MB L2, 2000MT/s HTT)
Time in Seconds (lower is better)
Performance was very close between the two here with an eight second advantage in favour of the 1333MHz FSB chip.  That's less than a one percent performance increase, but we'll take everything we can get for free at the same clock speed.  The poor Athlon 64 X2 6000+ really takes a battering in this test though, with the E6600 over two minutes faster than it.
MP3 Encoding:
We used LAME MT for our audio encoding test - it’s the multithreaded version of the popular LAME MP3 encoder.  We ran tests with both Intel’s and Microsoft’s compilers - naturally, the Intel compiler resulted in some performance increases on Intel’s processors.  We converted all 18 tracks from Moby’s popular
Play album to a 192kbps variable bit-rate MP3.
          50
          75
          100
          125
          150
          175
          50
          75
          100
          125
          150
          175
MP3 to WAV Decoding:
For our decoding test, we converted the MP3 tracks created in the previous test back to .WAV format, saving the output to a different folder.
We saw no differences in our MP3 encoding tests, but there were some slight advances that went in favour of the E6750 in the decoding tests.
