Kingston HyperX KHX9600D2K2/2G
June 21, 2007 | 14:18
Tags: #9600 #ddr2 #enthusiast #expensive #extreme #fast #overclocking #pc2
Companies: #hyperx #kingston
Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multi-threaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio. We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
Xvid Encoding
VirtualDub MPEG-2 1.6.15, Xvid 1.2 beta, 276MB .mpg to 100MB .avi
  • Kingston HyperX KHX9600D2K2/2G (800MHz)
  • Corsair CM2X1024-9136C5D (800MHz)
  • Corsair CM2X1024-10000C5D (800MHz)
  • Corsair CM2X1024-9136C5D (1142MHz)
  • Kingston HyperX KHX9600D2K2/2G (1200MHz)
  • Corsair CM2X1024-9136C5D (1200MHz)
  • Kingston HyperX KHX9600D2K2/2G (1232MHz)
  • Corsair CM2X1024-10000C5D (1250MHz)
  • 706
  • 698
  • 698
  • 696
  • 700
  • 694
  • 691
  • 689
200
300
400
500
600
700
Time in Seconds (lower is better)
The Kingston is consistently slightly slower than everything else, and has a good six seconds between it at native 1200MHz and the equivalent overclocked Corsair PC2-9136. Even at 800MHz low latency, there's some eight seconds difference. This may seem a lot but it's a field with a tight spread still.
MP3 Encoding:
We used LAME MT for our audio encoding test - it's the multi-threaded version of the popular LAME MP3 encoder. We ran tests with both Intel's and Microsoft's compilers - naturally, the Intel compiler resulted in some performance increases on Intel's processors. We converted all 18 tracks from Moby's popular Play album to a 192kbps variable bit-rate MP3.
MP3 Encoding (Intel)
LAME 3.97, Moby - Play, .wav to 192KHz .mp3, Intel Compiler
  • 103
  • 100
  • 100
  • 100
  • 103
  • 102
  • 101
  • 101
50
75
100
MP3 Encoding (Microsoft)
LAME 3.97, Moby - Play, .wav to 192KHz .mp3, MS Compiler
  • 110
  • 111
  • 110
  • 110
  • 110
  • 110
  • 109
  • 109
50
75
100
125
With the Intel compiler the Kingston is at most a second or two slower, but there's really nothing in it across the entire MP3 encoding tests. Yet again, at the stock 1200MHz speed the Kingston is a slower than the rest of the field, however.
MP3 Decoding
MP3 Decoding (Intel)
LAME 3.97, Moby - Play, .192KHz .mp3 to .wav, Intel Compiler
  • 37
  • 30
  • 32
  • 31
  • 36
  • 37
  • 36
  • 36
20
30
40
MP3 Decoding (Microsoft)
LAME 3.97, Moby - Play, .192KHz .mp3 to .wav, MS Compiler
  • 40
  • 35
  • 35
  • 34
  • 37
  • 40
  • 37
  • 40
20
30
40
The MP3 decoding tests are again a mixed bag. At 800MHz the Kingston is a full 14 and 23 percent slower, than the competition, but at a native 1200Mhz and overclocked 1232MHz the Kingston is faster than the equivalent Corsair's.
