Brightness and Contrast
We measure the maximum and minimum brightness of each screen in candela per square metre. For the maximum, values over 250cd/m
2 should be sufficient for the majority of environments, while for the minimum the closer to 0 the better, as this will lead to darker and deeper blacks. Dividing the maximum value by the minimum gives us the monitor's contrast ratio.
Acer Predator GN246HLBbid
AOC G2460Pqu
ASUS VG248QE
ASUS VG278H
BenQ RL2455HM
BenQ XL2720Z
Eizo Foris FG2421
Iiyama ProLite E2473HS-GB1
Iiyama ProLite GB2488HSU
Philips 242G5DJEB
Samsung U28D590D
353
421
389
278
301
261
260
289
394
382
426
Brightness (cd/m2)
AOC G2460Pqu
ASUS VG248QE
ASUS VG278H
BenQ RL2455HM
BenQ XL2720Z
Eizo Foris FG2421
Philips 242G5DJEB
Samsung U28D590D
0.43
0.38
0.40
0.24
0.36
0.29
0.07
0.30
0.60
0.37
0.53
0.2
0.3
0.4
0.5
0.6
Brightness (cd/m2)
Eizo Foris FG2421
ASUS VG278H
AOC G2460Pqu
Philips 242G5DJEB
ASUS VG248QE
BenQ XL2720Z
BenQ RL2455HM
Samsung U28D590D
3714.3 : 1
1158.3 : 1
1107.9 : 1
1032.4 : 1
972.5 : 1
963.3 : 1
900 : 1
836.1 : 1
820.9 : 1
803.8 : 1
656.7 : 1
Contrast ratio - higher is better
Brightness Uniformity
For this measurement, we divide the screen into sections and take maximum brightness readings from each. The value presented is the value from the dimmest area as a percentage of that of the brightest. Above 75 percent is considered acceptable, above 80 good and above 85 very good.
BenQ XL2720Z
ASUS VG278H
BenQ RL2455HM
ASUS VG248QE
AOC G2460Pqu
Samsung U28D590D
Eizo Foris FG2421
Philips 242G5DJEB
85
83
83
82
80
80
80
79
79
79
78
20
30
40
50
60
70
80
90
Brightness uniformity (%) - higher is better
Viewing Angles
Finally, we also measure the brightness at a 45 degree viewing angle from the side, top and bottom. From the side, values above 47 percent are good while the best panels will be over 50 percent. From the vertical perspectives, 15 percent is good and 20 percent is very good.
Samsung U28D590D
ASUS VG248QE
ASUS VG278H
AOC G2460Pqu
Philips 242G5DJEB
BenQ XL2720Z
BenQ RL2455HM
Eizo Foris FG2421
62
55
53
52
50
50
50
46
46
42
31
Brightness (%) - higher is better
Samsung U28D590D
ASUS VG278H
Eizo Foris FG2421
BenQ XL2720Z
BenQ RL2455HM
Philips 242G5DJEB
ASUS VG248QE
AOC G2460Pqu
25
25
24
22
20
18
11
10
10
9
8
Samsung U28D590D
ASUS VG278H
Eizo Foris FG2421
AOC G2460Pqu
ASUS VG248QE
Philips 242G5DJEB
BenQ RL2455HM
BenQ XL2720Z
31
29
24
20
11
11
11
10
8
7
5
