Gaming Monitor Roundup 2014
Written by bit-tech Staff
July 21, 2014 | 11:23
Tags: #1080p #120hz #144hz #1ms #gaming-monitor #gaming-screen #refresh-rate #response-time
Companies: #bit-tech
Colour Accuracy
This value represents how close the colours a monitor outputs are to the colours it should be displaying. It's calculated using the Delta E 1994 formula and is the average of six readings (red, green, blue, cyan, magneta and yellow). Values under 1 are considered imperceptible (and usually only achievable on professional displays or with a colorimeter and calibration software), while values under 3 are very good and under 5 are still decent. Values over 10 will result in noticeable colour inaccuracies.
Colour Accuracy
Average Delta E (1994 formula)
  • Iiyama ProLite GB2488HSU
  • Acer Predator GN246HLBbid
  • Iiyama ProLite E2473HS-GB1
  • Samsung U28D590D
  • Eizo Foris FG2421
  • BenQ RL2455HM
  • Philips 242G5DJEB
  • BenQ XL2720Z
  • ASUS VG248QE
  • AOC G2460Pqu
  • ASUS VG278H
  • 1.7
  • 1.9
  • 2.7
  • 2.7
  • 3.2
  • 4.2
  • 4.8
  • 4.8
  • 5.5
  • 6.5
  • 6.9
5
6
7
Average Delta E (mΔuv) - lower is better
Grayscale Tracking
This value represents how well a monitor is able to keep white values neutral at multiple levels of brightness. It's calculated using the Delta E 1994 formula and is the average of ten measured values between 10 and 100 percent brightness using 10 percent intervals. Good and bad values are the same as they are for colour accuracy.
Grayscale Tracking
  • Philips 242G5DJEB
  • Samsung U28D590D
  • Eizo Foris FG2421
  • BenQ XL2720Z
  • ASUS VG248QE
  • AOC G2460Pqu
  • ASUS VG278H
  • BenQ RL2455HM
  • 3.0
  • 3.3
  • 3.5
  • 3.6
  • 5.7
  • 5.8
  • 6.4
  • 6.5
  • 7.4
  • 10.5
  • 15.6
8
10.5
13
15.5
18
