Colour accuracy is determined by displaying a series of different test colours and comparing the displayed value (as measured by the colorimeter) to the expected, ideal value. A complicated formula then outputs what is known as a delta E value, which in simple terms represents how far the displayed colour is from the ideal. Lower values are preferred, since that means the distance is less.
Colour Accuracy
Datacolor Spyder4Elite
ViewSonic VX2776-smhd
Philips Moda 245C7QJSB
Iiyama G-Master GB2888UHSU-B1
AOC G2460PF
Asus MG28UQ
BenQ Zowie XL2411
0.63
5.71
0.98
2.80
1.89
6.48
3.44
8.01
4.38
9.37
4.76
8.52
8
10.5
Delta E (Lower Is Better)
Average
Maximum
Gamma, meanwhile, refers to how a monitor deals with and corrects for the non-linear relationship between the amount of voltage applied to a pixel and the amount of light emitted. As such, it mainly affects the output of mid-range and greyscale colours. We are looking for a value of 2.2, which is in line with the standard sRGB colour space.
Click to enlarge - Gamma 1.8 setting Click to enlarge - Gamma 2.0 setting Click to enlarge - Gamma 2.2 setting (default) Click to enlarge - Gamma 2.4 setting Click to enlarge - Gamma 2.6 setting
