ASRock Fatal1ty Professional-M Review
Written by Paul Goodhead
May 16, 2012 | 09:51
Tags: #asrock-z68-extreme4-gen3 #best-moth #fatal1ty #fatality #overclocking-motherboard #z77 #z77-motherboard #z77-motherboard-review
Companies: #asrock
Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake, and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while an HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Multi-tasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase with which we're all familiar, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking
mPlayer and 7-Zip
  • Intel DZ77GA-70K
  • Asus Maximus V Gene
  • Gigabyte GA-Z77-UD5H
  • ASRock Fatal1ty Professional-M
    • 1846
    • 1999
    • 1831
    • 1971
    • 1767
    • 1908
    • 1673
    • 1913
1000
1500
2000
Points, higher is better
  • Stock
  • Overclocked
Read our performance analysis.
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests.
Overall Score
Gimp, Handbrake, mplayer, 7-Zip
  • Intel DZ77GA-70K
    • 2403
    • 2836
    • 2373
    • 2832
    • 2373
    • 2741
    • 2259
    • 2839
1000
1500
2000
2500
3000
  • Stock
  • Overclocked
