Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High.  Because of how intense the game is, we tested without anti-aliasing or anisotropic filtering enabled, and at a resolution of 1,680 x 1,050.  There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel if you wish.
        ASRock H55M Pro
        Zotac H55-ITX WiFi
        Asus P7H57D-V Evo
        Gigabyte GA-P55M-UD2
        Gigabyte GA-H55M-UD2H
        ASRock P55 Extreme4
        ASRock P55M Pro
Frames Per Second - higher is better
        Asus P7H57D-V Evo
        ASRock P55M Pro
        Zotac H55-ITX WiFi
        ASRock P55 Extreme4
        ASRock H55M Pro
Read our
performance analysis.
