Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake, and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while an HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
Multi-tasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase with which we're all familiar, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
        Gigabyte GA-Z68A-D3H-B3
        Biostar TP67XE (B3)
        Asus P8P67
        Asus Sabertooth P67
        Asus P8P67-M Pro
        MSI P67A-GD53 (B3)
        ASRock P67 Extreme 4
        ASRock Z68 Extreme4 Gen3
Points, higher is better
Read our
performance analysis.
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests.
        Asus Sabertooth P67
        Asus P8P67-M Pro
        Biostar TP67XE (B3)
        Asus P8P67
        MSI P67A-GD53 (B3)
          1000
          1500
          2000
          2500
          3000
Read our
