File Compression & Encryption:
Website: WinRAR
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt a 176MB MPEG-2 source file with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs with the same compression settings.
Asus M3A32-MVP Deluxe
Asus CrossHair II
Gigabyte GA-MA78G-DS3H
50
75
100
125
150
175
Time in seconds (lower is better)
PCI-Express Graphics
Integrated Graphics
Asus CrossHair II
Integrated Graphics
The AMD 790FX is overall slightly faster than the Asus CrossHair II Formula, and the mGPU does make a slight performance hit when enabled but both are faster than the AMD 780G thanks to the faster CPU support.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
Asus CrossHair II
Integrated Graphics
Asus CrossHair II
Integrated Graphics
In decompression both the AMD 790FX and CrossHair II Formula are pretty identical, and both out perform the AMD 780G again slightly.
