Asus P7P55D Deluxe Review
September 9, 2009 | 11:50
Tags: #analysis #crossfire #deluxe #detail #mobo #motherboard #p55 #p7p55d #pictures #result #review #sli
Companies: #asus #test
File Compression & Encryption:
Website: WinRAR
We used the Intel X25-M SSD to provide a uniform performance base between all the boards tested in file compression and decompression.
Large File Compression & Encryption
WinRAR 3.71, Multithreaded, 276MB source file
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 70.5
    • 55.5
    • 71.0
    • 50.5
20
30
40
50
60
70
Seconds (lower is better)
  • Stock
  • Overclocked
Small File Compression & Encryption
WinRAR 3.71, Multithreaded, 400 2048x1536 Photos
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 72.0
    • 58.0
    • 73.0
    • 53.0
20
30
40
50
60
70
80
  • Stock
  • Overclocked
Again both boards perform almost identically when at stock speeds, but consistently the Asus is faster by five seconds or around ten per cent in both cases.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
Large File Decompression & Decryption
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 13.5
    • 13.5
    • 15.0
    • 12.0
8
10.5
13
15.5
  • Stock
  • Overclocked
Small File Decompression & Decryption
  • Asus P7P55 Deluxe
  • MSI P55 GD65
    • 21.0
    • 18.5
    • 21.0
    • 19.0
10
15
20
  • Stock
  • Overclocked
Overall we think the Asus comes out again on top here as it commands the slight and consistent advantage when overclocked. Clearly the SATA performance picks up when under load as we use the same Intel X25-M SSD in this test as we do to check the raw bandwidth numbers.
