Asus P7P55D Deluxe Review
September 9, 2009 | 11:50
Tags: #analysis #crossfire #deluxe #detail #mobo #motherboard #p55 #p7p55d #pictures #result #review #sli
Companies: #asus #test
Lavalys Everest 5.0.1667 Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 12907.0
    • 10756.0
    • 14604.0
    • 12309.0
    • 10253.0
    • 13827.0
5000
7500
10000
12500
15000
MB/s (higher is better)
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Performance Test (OC)
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 18894.0
    • 15341.0
    • 20514.0
    • 16764.0
    • 15584.0
    • 19361.0
10000
15000
20000
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Latency Test
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 53.1
    • 38.0
    • 55.1
    • 41.7
20
30
40
50
60
Nanoseconds (lower is better)
  • Stock
  • Overclocked
The much cheaper MSI P55 GD65 trumps the Asus everywhere in raw bandwidth here. Only overclocked the Asus commands a fractionally higher write speed thanks to its marginally superior base-clock, but that doesn't count for too much. It's strange, since the MSI is only running its memory at 1,900MHz CL8, whereas the Asus is at 2,000MHz CL8, with the same set of DIMMs when overclocked. Even at stock speeds, both are running at 1,333MHz CL9 and the MSI is lower latency and commands a few hundred MB/s edge.
SiSoftware Sandra Lite 2009 SP4 (15.125) Pro Business
Website: Sisoftware
SiSoft Sandra Memory Bandwidth
  • Asus P7P55 Deluxe
  • MSI P55 GD65
    • 16052.0
    • 19174.8
    • 16043.3
    • 22428.5
10000
15000
20000
25000
  • Stock
  • Overclocked
SiSoft Sandra Memory Latency
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 74
    • 53
    • 81
    • 59
20
30
40
50
60
70
80
90
  • Stock
  • Overclocked
Sisoft Sandra claims the Asus is fractionally faster on average at stock speeds, but the MSI then mullers it when overclocked, despite the clock advantage.
Mod of the Month October 2020 in Association with Corsair
November 6 2020 | 17:30
