Asus P7P55D Deluxe Review
September 9, 2009 | 11:50
Tags: #analysis #crossfire #deluxe #detail #mobo #motherboard #p55 #p7p55d #pictures #result #review #sli
Companies: #asus #test
GIMP Image Editing
Website: GNU Image Manipulation Program (GIMP)
GIMP Image Editing
CustomPC Benchmark
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 292
    • 227
    • 293
    • 218
100
150
200
250
300
Seconds (lower is better)
  • Stock
  • Overclocked
The Asus and MSI boards are evenly matched at stock speeds in image encoding, on average, and the extra base clock and core speed works for Asus' advantage when overclocked as it shaves a tidy nine seconds, or four per cent off the MSI performance.
Handbrake H.264 Encoding
Website: HandBrake
Our test uses HandBrake - an open-source, GPL-licensed, multiplatform, multithreaded video transcoder, available for MacOS X, Linux and Windows - to encode a high resolution MPEG-2 video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
Handbrake h.264 Video Encoding
CustomPC Benchmark
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 335
    • 255
    • 338
    • 250
100
150
200
250
300
350
  • Stock
  • Overclocked
At stock speeds the MSI slivers ahead - mostly because of its memory bandwidth advantage, but the clock frequency helps the Asus board when overclocked as it claws back virtually the same advantage.
Multitasking Performance
Website: MPC-HC
Website: 7-Zip
Multitasking Test
CustomPC Benchmark
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 144
    • 105
    • 147
    • 116
50
75
100
125
150
  • Stock
  • Overclocked
Multi-tasking does not seem to favour the Asus board though, where the MSI clearly strikes nearly a ten per cent advantage when overclocked, and just slightly at stock speeds.
