Testing Methods
With the exception of ATTO, which we use to measure the performance of a motherboard's SATA controllers, all of our benchmarks use real applications that give you a great idea of how well a product fares when performing the tasks for which you're likely to use it.
We test with our own Media Benchmarks suite, which can be downloaded so that you can test your own system. It uses a combination of Gimp image editing, H.264 encoding with Handbrake and multi-tasking with 7-Zip file compression combined with HD video playback. Finally, for our game testing we benchmark the board running Arma II, and record the minimum and average frame rates.
Our benchmarks include stable overclocked results too, so you can gauge how much performance potential there is in the motherboard, and how much value this adds to your purchase.
Asus P8P67-M Pro Review Asus P8P67-M Pro Test Setup
Test Setup:
Motherboards:
  • Asus P8P67-M Pro (Intel LGA1155)
  • MSI P67A-GD53 (B3) (Intel LGA1155)
  • ASRock P67 Extreme4 (Intel LGA1155)
  • Asus Sabertooth P67 (Intel LGA1155)
  • Asus P8P67 (Intel LGA1155)
Common Components:
Overclocked Settings:
  • Asus P8P67-M Pro - 5.1GHz, 100MHz Base Clock, 51x multiplier, 1,600MHz dual-channel DDR3 memory at 8-8-8-24-74-1T
  • MSI P67A-GD53 (B3) - 5GHz, 100MHz Base Clock, 50x multiplier, 1,600MHz dual-channel DDR3 memory at 8-8-8-24-74-1T
  • ASRock P67 Extreme 4 - 4.9GHz, 100MHz Base Clock, 49x multiplier, 1,600MHz dual-channel DDR3 memory at 8-8-8-24-74-1T
  • Asus Sabertooth P67 - 4.9GHz, 100MHz Base Clock, 49x multiplier, 1,600MHz dual-channel DDR3 memory at 8-8-8-24-74-1T
  • Asus P8P67 - 5GHz, 100MHz Base Clock, 50x multiplier, 1,600MHz dual-channel DDR3 memory at 8-8-8-24-74-1T
