Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested without anti-aliasing or anisotropic filtering enabled, and at a resolution of 1,680 x 1,050. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel if you wish.
It should be noted that the Rampage III Gene was tested with version 10.5 of ATI Catalyst display driver installed. All other boards were tested with version 10.2 installed.
Asus Rampage III Gene
Asus P6X58D-E
Asus P6X58D Premium
Asus P6TD Deluxe
Gigabyte GA-X58A-UD7
EVGA X58 SLI Micro
Asus Rampage III Extreme
Frames Per Second - higher is better
Asus P6TD Deluxe
Asus P6X58D-E
Asus P6X58D Premium
EVGA X58 SLI Micro
See the
Performance Analysis page for discussion of this graph.
