Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with both anti-aliasing and anisotropic filtering disabled at resolutions above 1,680 x 1,050 for the time being. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
Asus P6T Deluxe
Gigabyte GA-EX58-UD4P
MSI Eclipse SLI
Gigabyte GA-EX58-UD3R
Asus Rampage II Gene
MSI X58 Pro
Foxconn Blood Rage
Foxconn Renaissance
Gigabyte GA-EX58-DS4
41.4
39.7
39.5
39.5
39.4
39.3
39.2
38.9
38.8
Frames Per Second - higher is better
The
Crysis performance is pretty average although there's not a lot in it to be honest, however we don't see the gains the P6T provided. If anything, at least the Gene is consistent.
Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft, and while it continues the
Far Cry franchise that Crytek started in 2004, this game is built on its own in-house engine and has no association - other than its name - to anything Crytek has worked on or is working on now. We used a retail version of the game patched to version 1.02, and used the in-built "Action" gameplay demo set to Ultra-Very High settings under DirectX 10.
MSI X58 Pro
Asus P6T Deluxe
Foxconn Blood Rage
Foxconn Renaissance
MSI Eclipse SLI
Despite the average FPS being quite high in
Far Cry 2, the minimum FPS are considerably lower at sub 40FPS.
