SATA and M.2 Performance
Website: CrystalDiskMark
We test SATA performance with a Samsung SSD 850 Pro, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For M.2 port testing, we use a Samsung SSD 950 Pro. This is rated at 2200MB/sec read and 900MB/sec write speeds - not quite saturating the M.2 PCI-E 3.0 x4 interface but enough to give it a good workout. We use CystalDiskMark's 32QD sequential test.
        Asus ROG Strix X99 Gaming
        MSI X99A XPower Titanium
          200
          300
          400
          500
          600
    MB/sec
          1000
          1500
          2000
          2500
    MB/sec
Rightmark Audio Analyzer
Publisher: Rightmark
We use the Playback/Recording test, first adjusting levels so they're within the benchmark parameters and then using 24-bit 192KHz tracks, we connect the line-in to the speaker/line-out jack using a standard 3.5mm audio cable. Following feedback we felt it important to include some results given that on-board audio is a hotly fought-over area with motherboards at the moment.
        Gigabyte X99-Gaming 5P
        Asus Sabertooth X99
        Asus X99-A II
        ASRock Fatal1ty X99M Killer
        MSI X99A XPOWER AC
        ASRock X99 Extreme 11
        Asus X99 Deluxe
        EVGA X99 Micro
        Asus X99-Pro
        Gigabyte X99M-Gaming 5
        Gigabyte GA-X99-UD4P
        Gigabyte GA-X99-Gaming 5
        MSI X99S SLI Plus
        MSI X99S MPower
dBA (Higher Is Better)
        Asus Sabertooth X99
        Asus X99-A II
        MSI X99A XPOWER AC
        Asus X99 Deluxe
        Asus X99-Pro
        EVGA X99 Micro
        MSI X99S MPower
        MSI X99S SLI Plus
dBA (Lower Is Better)
        Asus X99-A II
        Asus X99 Deluxe
        MSI X99S SLI Plus
        Asus X99-Pro
        Asus Sabertooth X99
        MSI X99A XPOWER AC
        EVGA X99 Micro
        MSI X99S MPower
          0.005
          0.0075
          0.01
          0.0125
    THD Percentage (Lower Is Better)
