[b]SATA Performance
Website: [/b]
ATTO Disk Benchmark
We tested the SATA and performance with an OCZ Vector 128GB, as this is one of the fastest SSDs we've ever tested, and it can test the maximum speed of SATA 3Gbps and SATA 6Gbps ports.
We use ATTO Disk Benchmark, and take the read and write speeds for 1,024KB data chunks.
        Asus Z87i-Pro (Intel Z87)
        MSI Z87-G45 Gaming
        Asus Maximus VI Hero (Intel Z87)
         Asus Maximus VI Extreme (Intel Z87)
        Asrock Z87 Extreme3
        Gigabyte GA-Z87X-UD3H
        Intel DZ87KLT-75K (Intel Z87)
        Asus Maximus VI Hero ASMedia ASM1061
         Asus Maximus VI Extreme (ASM1061 controller)
        Intel DZ87KLT-75K (Marvel 88SE9172 controller)
        Gigabyte GA-Z87X-UD3H (Marvel 88SE9172 controller)
          200
          300
          400
          500
          600
    MB/sec, higher is better
Power Consumption
Website: Prime95
To see how much power the motherboard consumed at idle and load and while at stock speeds and when overlcocked, we used Prime95 to stress the CPU to its limits, putting all eight cores of our Core i7-4770K test CPU under load and allowing the power readout to level off.
        Gigabyte GA-Z87X-UD3H (3.5GHz/4.7GHz)
        Asrock Z87 Extreme3
        MSI Z87-G45 Gaming
        Asus Z87i-Pro
        Asus Maximus VI Hero (3.5GHz/4.7GHz)
        Asus Maximus VI Extreme (3.5GHz/4.7GHz)
        Intel DZ87KLT-75K (3.5GHz/4.7GHz)
Watts, lower is better
        Asrock Z87 Extreme3 (3.5GHz/4.6GHz)
        MSI Z87-G45 Gaming (3.5GHz/4.7GHz)
        Asus Z87i-Pro
