Asus Maximus Formula & Maximus Extreme
November 22, 2007 | 08:02
Tags: #analysis #benchmarks #crossfire #edition #extreme #formula #gamers #gladiator #performance #republic #review #special #x38
Companies: #asus #ati #intel
Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multi-threaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio. We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
Xvid Encoding
VirtualDub MPEG-2 1.6.15, Xvid 1.2 beta, 276MB .mpg to 100MB .avi
  • Asus Maximus Extreme - 7900 GTX
  • Asus Maximus Extreme - X1900 CF
  • Asus Maximus Formula - 7900 GTX
  • Asus Maximus Formula - X1900 CF
  • Gigabyte GA-X38-DS5 - 7900 GTX
  • Gigabyte GA-X38-DS5 - X1900 CF
  • Gigabyte GA-X38T-DQ6 - 7900 GTX
  • Gigabyte GA-X38T-DQ6 - X1900 CF
  • Abit IP35 Pro - 7900 GTX
  • Abit IP35 Pro - X1900 CF
  • 714.7
  • 716.3
  • 728.3
  • 733.3
  • 734.3
  • 738.0
  • 725.0
  • 723.3
  • 733.7
  • 616.0
200
300
400
500
600
700
800
Time in Seconds (lower is better)
The Extreme shaves about 10-20 seconds off the Gigabyte and single card Abit times, with the Formula about equal to the other boards being compared. However, the Abit is still massively faster than the other boards in this test when using CrossFire but we can't actually attribute a reason why it's so fast. The settings never changed, the results were consistent and the output video file worked just fine.
MP3 Encoding:
We used LAME MT for our audio encoding test - it's the multi-threaded version of the popular LAME MP3 encoder. We ran tests with both Intel's and Microsoft's compilers - naturally, the Intel compiler resulted in some performance increases on Intel's processors. We converted all 18 tracks from Moby's popular Play album to a 192kbps variable bit-rate MP3.
MP3 Encoding (Intel)
LAME MT 3.97, Moby - Play, .wav to 192kbps .mp3, Intel Compiler
  • 89.0
  • 87.7
  • 116.3
  • 117.0
  • 88.0
  • 87.0
  • 87.3
  • 88.7
  • 114.3
  • 94.7
50
75
100
125
MP3 Encoding (Microsoft)
LAME MT 3.97, Moby - Play, .wav to 192kbps .mp3, MS Compiler
  • Asus Maximus Extreme - X1900CF
  • 96.3
  • 96.7
  • 122.3
  • 125.0
  • 96.0
  • 96.0
  • 96.0
  • 95.7
  • 123.0
  • 98.0
50
75
100
125
In both cases the Extreme works great and it's as fast as the Gigabytes and the CrossFired Abit IP35 Pro. However, the Formula is consistently under performing in this test, just like the IP35 Pro does in a single card configuration.
MP3 Decoding
MP3 Decoding (Intel)
LAME MT 3.97, Moby - Play, .192KHz .mp3 to .wav, Intel Compiler
  • 28.0
  • 28.7
  • 36.3
  • 35.7
  • 28.3
  • 27.5
  • 29.7
  • 28.0
  • 39.0
  • 35.3
20
30
40
MP3 Decoding (Microsoft)
LAME MT 3.97, Moby - Play, .192KHz .mp3 to .wav, MS Compiler
  • 30.0
  • 29.5
  • 38.7
  • 37.7
  • 29.7
  • 29.5
  • 30.7
  • 30.3
  • 42.3
  • 33.0
20
30
40
In decoding the story is much the same - the Extreme keeps on par with the best of them but the Formula under performs and is consistently slower.
