File Compression & Encryption:
Website: WinRAR
We used the Intel X25-M SSD to provide a uniform performance base between all the boards tested in file compression and decompression.
DFI 790FX-B M2RSH
MSI DKA790GX Platinum
Seconds (lower is better)
DFI 790FX-B M2RSH
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
DFI 790FX-B M2RSH
DFI 790FX-B M2RSH
For the DFI, in both file compression and decompression it's faster by a few seconds, where at most it stretches an 8.6 percent lead over the MSI in small file compression performance - probably attributed to it's marginally higher HDD performance.
Multitasking Performance
Website: MPC-HC
Website: 7Zip
To run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM. Our multitasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using Media Player Classic, making it a seriously demanding test for any PC.
DFI 790FX-B M2RSH
In multitasking, there's very little between both the boards on average, with the DFI stretching out a two second lead that just isn't very noticeable in the real world.
