Gigabyte GA-E350N-USB3 Review
February 23, 2011 | 08:31
Tags: #apu #brazos #htpc #mini-itx #motherboard #performance #result #review
Companies: #amd #gigabyte #test
Media Benchmarks
Download from: bit-tech.net
We've developed our own suite of benchmarks using real-world and open-source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake, and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while a HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring system is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
GIMP Image Editing
Website: GNU Image Manipulation Program (GIMP)
Far from being some kind of pr0n-filtering tool, Gimp is an open source image editing application - Gimp is an acronym of GNU Image Manipulation Program. Our test simulates how well a PC can manipulate a collection of large digital photos, and to achieve a low time requires a PC with a powerful CPU, plenty of quick memory and efficient hard disk drive access.
GIMP Image Editing
Media Benchmarks
  • Intel Core 2 Duo SU7300
  • VIA Nano 'Dual-Core'
  • AMD V Series V105
  • AMD E-350 APU
  • VIA Nano U2500
  • Intel Atom D330
  • 467
  • 434
  • 379
  • 352
  • 194
  • 193
200
300
400
500
Points (Higher is Better)
Handbrake H.264 Encoding
Website: HandBrake
We use the open-source, GPL-licensed, multi-platform, multi-threaded video encoder Handbrake to encode a HD video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
Handbrake h.264 Video Encoding
Media Benchmarks
  • AMD E-350 APU
  • Intel Atom D330
  • AMD V Series V105
  • VIA Nano U2500
  • 532
  • 472
  • 467
  • 359
  • 275
  • 193
200
300
400
500
Multi-tasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase that we're all familiar with, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking Test
Media Benchmarks
  • VIA Nano Dual-Core
  • AMD E-350 APU
  • Intel Atom D330
  • AMD V Series V105
  • VIA Nano U2500
  • 304
  • 258
  • 0
  • 0
  • 0
  • 0
100
150
200
250
300
For a full performance analysis of the above graphs, see page 8.
