Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with both anti-aliasing and anisotropic filtering disabled at resolutions above 1,680 x 1,050 for the time being. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
MSI P55 GD65
Asus P7P55 Deluxe
Gigabyte GA-P55M-UD4
Frames Per Second - higher is better
Asus P7P55 Deluxe
MSI P55 GD65
MSI P55 GD65
Asus P7P55 Deluxe
Crysis gaming performance aws consistently disappointing at stock speeds, as the Gigabyte board barely kept up when we used a single GPU. With two graphics cards installed, performance fell right off when compared to both the MSI and Asus boards.
We put quite a lot of time into retesting and checking these results, but they were completely consistent, often down to the hundredths of a frame per second.
Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft, and while it continues the
Far Cry franchise that Crytek started in 2004, this game is built on its own in-house engine and has no association - other than its name - to anything Crytek has worked on or is working on now. We used a retail version of the game patched to version 1.02, and used the in-built "Action" gameplay demo set to Ultra-Very High settings under DirectX 10.
MSI P55 GD65
Asus P7P55 Deluxe
MSI P55 GD65
Asus P7P55 Deluxe
MSI P55 GD65
Asus P7P55 Deluxe
Far Cry 2 performance from the Gigabyte is notably better, as the board surprisingly performs consistently better with Nvidia GPUs than ATI. The board was ahead of the pack with a single Geforce GTX 260, but lagged behind by several fps when two ATI cards in CrossFire were installed.
