File Compression & Encryption:
Website: WinRAR
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
Gigabyte GA-X48T-DQ6
XFX nForce 790i Ultra SLI
XFX nForce 780i SLI
MSI P35 Diamond
Time in Seconds (lower is better)
XFX nForce 780i SLI
MSI P35 Diamond
Gigabyte’s X48T-DQ6 performs top in the small file compression by a small margin, but it drops a few seconds in large compression testing compared to the XFX nForce 790i Ultra SLI. It is faster than both the XFX nForce 780i SLI and the MSI though.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
XFX nForce 780i SLI
MSI P35 Diamond
XFX nForce 780i SLI
MSI P35 Diamond
Decompression testing and again the X48T-DQ6 performs consistently better or as good as the fastest boards, although there's
very little in it across everything.
