Intel Pineview review and Jetway mini-ITX
February 10, 2010 | 11:33
Tags: #atom #low-power #mini-itx #mobo #molex #motherboard #perform #performance #pineview #result #review #sff
Companies: #jetway #test
We were unable to do a direct clock-to-clock memory comparison because the motherboards limited the manipulation of the FSB and there was no multiplier adjustment available.
Lavalys Everest 5.0.1667 Memory Performance
Website: Lavalys
Everest Memory Read Test
  • Intel Atom D510 (1.67GHz - 2 core, 4 thread)
  • Intel Atom D410 (1.67GHz - 1 core, 2 thread)
  • Intel Atom D230 (1.60GHz - 1 core, 2 thread)
  • Intel Atom D330 (1.60GHz - 2 core, 4 thread)
  • 4256
  • 4253
  • 3269
  • 2632
2000
3000
4000
MB/s (higher is better)
Everest Memory Write Test
  • 3044
  • 3034
  • 2830
  • 2837
1000
1500
2000
2500
3000
Everest Memory Copy Test
  • 3019
  • 3007
  • 2342
  • 1994
1000
1500
2000
2500
3000
Everest Memory Latency Test
  • 94.9
  • 95.9
  • 107.6
  • 111.6
50
75
100
125
nanoseconds (lower is better)
The benefit of faster memory and Front Side Bus is clearly shown here in Everest with the newer CPUs. We're not entirely sure of the memory settings applied on the Jetway boards, since there's no option within the BIOS apart from '800MHz', and no program (even CPU-Z) can read either from within the OS. We assume it's simply SPD settings of our memory: 5-5-5-18 at 800MHz, compared to 4-4-4-10 at 533MHz on the older Atom boards.
The effect of a second core might not seem to make a difference or have an impact, but Everest is still a single-threaded benchmark, unlike Sisoft Sandra...
SiSoftware Sandra Lite 2010c (16.26) Lite
Website: Sisoftware
SiSoft Sandra Memory Bandwidth
  • 2153.0
  • 1887.0
  • 1883.0
  • 1415.0
1000
1500
2000
SiSoft Sandra Memory Latency
  • 165.0
  • 169.0
  • 176.0
  • 193.0
100
150
200
The latency is clearly lower on the new Pineview systems, thanks to the increase in Front Side Bus and memory clocks, as is the bandwidth compared to the single-core D230. However, we still feel the D330 system is giving erroneous readings, even if they are entirely repeatable and consistent across many memory sticks.
