Lavalys Everest Memory Performance
Website: Lavalys
J&W Minix 780G (AMD 780G/SB700 - BE-2350)
J&W Minix 780G (AMD 780G/SB700 - LE-1200)
Jetway JNC62K (GeForce 8200 - BE-2350)
Jetway JNC62K (GeForce 8200 - LE-1200)
2000
3000
4000
5000
6000
MB/s (higher is better)
Read (MB/s)
Write (MB/s)
Copy (MB/s)
J&W Minix 780G (AMD 780G/SB700)
Jetway JNC62K (GeForce 8200)
Nanoseconds (lower is better)
Athlon 64 X2 BE-2350
Sempron LE-1200
While there is little difference in latency, the dual channel memory of the J&W MINIX means it has considerably better read and copy performance than the single 2GB stick in the Jetway motherboard.
SiSoftware Sandra Lite XII.2008.SP2c (14.24)
Website: Sisoftware
2000
3000
4000
5000
Sempron LE-1200
100
150
200
250
300
350
Sempron LE-1200
Sisoft Sandra tells pretty much the same story, especially when a dual core CPU is used the J&W MINIX is 43 percent faster.
SATA and eSATA Performance
Website: HD Tach 3.0
20
30
40
50
60
70
80
90
Because eSATA and SATA come from the SB700 soutbridge, the performance is the same, but both are a
fraction less than the standard maximum of 82MB/s that the GeForce 8200-based Jetway board achieves.
USB 2.0 Performance
Unsurprisingly the USB performance of the AMD SB700 southbridge is hardly fantastic compared to the competition. If you have USB peripherals that are particularly sensitive to USB performance like external hard drives, then you might want to consider another chipset option like Nvidia or Intel.
