Jetway NC92-330-LF dual-core Atom mini-ITX
March 24, 2009 | 09:55
Tags: #16ghz #330 #945gc #atom #core #dual #htpc #hyperthreading #low #mini-itx #motherboard #performance #power #result #review #sff
Companies: #intel #jetway #test
Testing Methods:
With the exception of SiSoft Sandra, HD Tach and Lavalys Everest, all of our benchmarks have been engineered to give you numbers that you are likely to find useful when actually using the products we have evaluated in the real world.
As always, we did our best to deliver a clean set of benchmarks, with each test repeated three times and an average of those results is what we’re reporting here. In the rare case where performance was inconsistent, we continued repeating the test until we got three results that were consistent.
Test Setup:
  • Jetway NC92-330-LF with an Atom 330 CPU (2x1.6GHz with HyperThreading)
  • Shuttle X27-D with an Intel Atom 330 CPU (2x1.6GHz with HyperThreading)
  • Gigabyte GA-GC230D with an Intel Atom 230 CPU (1x1.6GHz with HyperThreading)
  • Jetway JNC62K with an AMD Sempron LE-1200 CPU (1x2.1GHz)
  • 2GB DDR2 533MHz at 3-3-3-9-2T (Intel Atom) or 800MHz at 5-5-5-18-2T (AMD).
  • Enermax 285W mATX PSU
  • Seagate 7200.10 200GB SATA hard drive
  • Windows Vista 32-bit SP1
Lavalys Everest Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • Jetway JNC62K (AMD Sempron LE-1200 1x2.1GHz)
  • Gigabyte GA-GC230D (Intel Atom 230 1x1.6GHz with HT)
  • Shuttle X27D (Intel Atom 330 2x1.6GHz with HT)
  • Jetway NC92-330-LF (Intel Atom 330 2x1.6GHz with HT)
    • 4179
    • 4315
    • 4001
    • 3332
    • 2834
    • 1206
    • 3079
    • 2830
    • 1190
    • 3065
    • 2834
    • 2288
2000
3000
4000
MB/s (higher is better)
  • Read (MB/s)
  • Write (MB/s)
  • Copy (MB/s)
Everest Memory Latency Test
    • 97.5
    • 110.7
    • 130.5
    • 140.6
50
75
100
125
150
Nanoseconds (lower is better)
  • Nanoseconds
Curiously some read/write performance has been sacrificed for a much improved CPU copy performance. We tested with a 1GB and 2GB DDR2 DIMM, as well as changing the memory timings to see if made a difference and found it was a BIOS level feature. Memory performance approaching uniformity means there are no bottlenecks, despite sacrificing some performance in other areas. It also improves the latency as well by a considerable amount (20 to 30ns) compared to the other Atom products.
SiSoftware Sandra Lite XII.2008.SP2c (14.24)
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
    • 3284.2
    • 1425.3
    • 1277.2
    • 1227.7
1000
1500
2000
2500
3000
3500
  • MB/s
Sisoft Sandra Random Memory Latency Test
    • 117
    • 189
    • 200
    • 256
100
150
200
250
  • Nanoseconds
Sisoft Sandra is less forgiving, affording a lower score to the Jetway board, but also a massively lower latency as well.
