File Compression & Encryption:
Website: WinRAR
We used the Intel X25-M SSD to provide a uniform performance base between all the boards tested in file compression and decompression.
MSI Eclipse SLI
Asus P6T Deluxe
20
30
40
50
60
70
80
Time in Seconds (lower is better)
MSI Eclipse SLI
Asus P6T Deluxe
20
30
40
50
60
70
80
In large file compression, the MSI Eclipse SLI is slightly slower on average, but in small file compression it's half a second faster - considering experimental error (the OS for example) and averaging, both boards are pretty much the same.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
MSI Eclipse SLI
Asus P6T Deluxe
MSI Eclipse SLI
Asus P6T Deluxe
Surprisingly the MSI Eclipse SLI is faster on both accounts, despite the fact it has a slightly slower ICH10R hard drive performance it beats the Asus by a small margin of a second and half a second in both cases.
Mulitasking Performance
Website: MPC-HC
Website: 7Zip
To run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM. Our multitasking test performs a massive file backup (with encryption) using 7Zip, while simultaneously playing back a HD movie file using Media Player Classic, making it a seriously demanding test for any PC.
MSI Eclipse SLI
Asus P6T Deluxe
50
75
100
125
150
175
In multitasking the MSI again comes out ahead, cutting four seconds off this couple of minute test over the Asus P6T - it's not much, but it does indicate a little higher efficiency in resource management for the MSI.
