You can see our in-depth look at MSI's modern EFI here, but its recent AMD boards now include controls for AMD's Precision Boost Overdrive (PBO), which can be found in the Overclocking/CPU features section, where you can set the scalar as well as limits for PPT, TDC, and EDC, which are some of the metrics used to determine the overclock PBO applies and are also displayed in Ryzen Master. As we can't test in a temperature-controlled lab we won't be testing PBO across different motherboards.
We've already mentioned the M.2 heatsink knocking nearly 20 degrees off the load temperature of our Samsung 960 Evo, but read and write speeds were recorded at 3,401MB/s and 1,872MB/s respectively. Audio performance was typical of Realtek's ALC 1220 audio codec, with a dynamic range of 114dBA and noise level of -114dBA. Idle power draw at stock speed was pleasingly low at 87W, while load power draw peaked at a hefty 544W once overclocked.
We're looking at one of the most high-end motherboards ever to grace our lab, and the MSI MEG X399 Creation is a superb motherboard in its own right, and as our recent AMD coverage proved, it's not only up to the task of dealing with AMD's new 16-core Threadripper CPU, but also its 32-core 2990WX CPU as well. The price, though, does mean you need to consider other aspects of the package when deciding whether it's right for you. The masses of fan headers and other cooling-related features mean this is a great motherboard for systems with liquid-cooling, and there are enough M.2 ports for monstrous SSD arrays, especially with the M.2 Xpander-Aero PCIe card included too.
There's little evidence yet, though, that other X399 boards would fare any worse here, and MSI already has an excellent Threadripper board in its X399 Gaming Pro Carbon AC. In fact, it has even more features in some areas but costs £130 less. If you're spending close to £1,000 or more on a CPU, though, then it's likely you may buy into the extra prowess on offer here, either with the insane number of M.2 ports or far more lavish power circuitry and cooling, especially if you're in the market for the 32-core CPU as well. If our wallets were that deep, we'd undoubtedly be building our Threadripper system using this monster motherboard too.
